Fusable link rerplacemnt for 2018 Hiace
gareth dinger
HI
Anyone know how to take out the alternator fusible link assembly  pt no. 82620-26510 from the housing (D block fuse housing) which is in front of motor under the body) as its bolted in ( got the two side bolts out ) and I  can't get enough lenght off the 3 cable bolten on to pull the fuse assembly out?
Edited by gareth dinger
correction
Ok found one simple way. I cut an inspection hatch/flap on the housing back to expose all five nuts. Once done sealed up hatch with tape/silicon. I know sound a bit rough but hell it saved hours of work!
