Does anyone by chance have the manual for recall R/2011/005?
ulflun
Does anyone by chance have the tech document / repair instructions for this recall? Recall number R/2011/005
"The issue affecting certain Avensis 2.0-litre and 2.4-litre petrol engine models, produced between July 2000 and September 2008, is related to potential concerns with the fuel system. The first concern is related to the fuel pipe, where small cracks can potentially develop after a long period of time. The second concern is related to potential insufficient tightening of the fuel pump check valve."
The recall is not longer active in Sweden but I think the car is affected by exactly this.
https://media.toyota.co.uk/toyota-announces-voluntary-recalls/
Toyota will not cover it as its a voluntary recall
does your car fit in that vin range? has the car had its recall done in the past
It is possible that during the manufacturing process, the wall thickness of the high-pressure supply pipe may have been reduced. If the driving conditions of the vehicle cause fuel pressure fluctuations this could cause cracking and result in a fuel leak. Also due to gasket fatigue and prolonged usage the high-pressure fuel pump check valve maybe come loose and leak.
Remedy
Recall all affected vehicles for the replacement of the fuel pipe and fuel pump check valve plus gasket.
