Engine Management Light Code P00BD
DaveYoung
I have the Engine Management light on and Code P00BD. I have had the MAF and EGR (both were faulty) replaced but light remains on.
Has anyone else had a similar issue?
Car is a 2017 RAV4
What is the flow rate at idle ?
disconnect the Battery and let everything reset,
have you had the Battery and alternator tested?
any recent jump starts?
Thanks for the reply.
No recent Jump starts
I've not had the Battery and alternator tested
MAF reads 1.67 lb/min when light on and 0.85 lb/min when fault code cleared.
I havent tried disconnecting Battery yet
  • 3 months later...
disconnect the battery and let everything reset,
have you had the battery and alternator tested?
I've not had the battery and alternator tested
I havent tried disconnecting battery yet
hi, I have a 2016 rav4 diesel 2.0 . the engine light is on and the code fault is p00bd. my garage has replaced the inlet manifold and a pressure sensor but light is still on, took it to Toyota and they recommended changing egr cooler and egr valve? are these connected with this issue? any ideas,,thanks..( car is running fine).
