Infotainement
courier
Hi new member .corrola 2019 hybred cvt.   Has anyone put a aftermarket infotainement head unit in.are there any problems wiring .coding etc.which unit did you use.if not can i get the unit upgraded.as its basic model.thanks
On cars with screens over dashboard it’s very difficult to add aftermarket infotainment systems. Plus if you do so you may loose car settings menu. Definitely not worth it. Just use the car as is and if you need more options best to buy a fully loaded car like excel spec Corolla.
