Front Brake Caliper
HighHamJam
Hello everyone, new member here. I have come on here looking to see if anyone can help me source a near side front brake caliper for my 2004 Estima. The part number is 47750-58010, I can find them in Japan but they are expensive, even without the shipping costs. The existing one on the car has seized. Is rebuilding the caliper an option, I see service kits are available to do this. If anyone could help that would be very much appreciated.
Many thanks, Pat.
you can get a rebuild kit no issue you willl need to check if the bore and piston are ok, i take it you have had the calliper off the car to confirm it's not a bad line holding fluid pressure
Topic moved to the Estima forum.
Could you cross reference the part number as it cant be unique to an estima and maybe just the same as the Camry etc?
