Idle Rpm Unstable
Tadzio
Avensis 2.0 99
Hi there,
On idle running I have noticed that sometimes RPM is unstable. Sometimes it's almost 1000 sometimes about 800 (in the same conditions: without A/C, lights,...)
Is this normal? During 60.000km inspection sparking plugs were changed. Could it be the reason? :unsure:
does it move between 800 - 1000 while running or sometimes go to 800rpm and other times 1000rpm?
i didn't have a clue. Jon's reply sounds good though
Try a decent service, make sure the plugs that go in are gapped correctly.
Do these engines have Idle control valves? Might need cleaning.
