Help
garry h
Is the car a new? If not I'd give it till it has about 1200 miles on it before you rev it too much. Just to be on the safe side for the long term.
4,700 miles is low for a 52 reg. Mines a 53 with nearly 14,000.
If the car is warm you should be fine (apart from the mpg). But the rev limiter is very quickly reached (specialy in 2nd).
