Replacing Yaris Door Speakers
seveer unaek
  • 1 year later...
This just 404'd for me, has the page been updated elsewhere :)
:edit:
crap, sorry to drag up such and old thread :( didn't see the dates until after I replied.
  • 3 months later...
Thanks for the guidance on fitting the aftermarket headunit - helped me fit mine successfully.
I want to try and fit an amplifier. I've already run the remote power wire and RCA leads out from the headunit. I need to run the amp power lead from the Battery through the bulkhead and into the car. Does anybody know where is the best place to run the wire through in the bulkhead IE which grommit/hole etc??
Thanks in advance for any help
I want to try and fit an amplifier. I've already run the remote power wire and RCA leads out from the headunit. I need to run the amp power lead from the battery through the bulkhead and into the car. Does anybody know where is the best place to run the wire through in the bulkhead IE which grommit/hole etc??
Look straight behind the Battery and you'll see a gromet with loads of wires... just push a screwdriver through there and pass the wire through... it eventually drops out and down behind the glovebox, then wire it where you want it. :thumbsup:
yeah just dont go what i did and get ragged off pullying gauge 0 cable thru and therefore pulling the grommet out of the bulkhead :(
Fought with that damn thing for like 2 hours, im sure that they build the car around the grommet!
  • 7 months later...
yep, was hoping on upgrading doors - was wondering how it all works before opening it all up, herd loads about people having to make stuff from mdf, and peoples windows not shuttin etc
was plannin on fitting 17cm ones this big:
Mounting depth 44.5 mm.
Size 179 x 179 x 75.3 mm.
and was wondering if they would fit?
im also in need of a guide very urgently as ive ripped (litterally ripped) my door Speakers out well just the drivers side atm coz i got scared by the headless screws are thy pot rivits?
