Side Repeaters...
Funkadelic
Mine have been removed (it's an import).
Do I need them back on the for the MOT?
If I do, how long will it take?
Do I need to get the wheel off?
I'm sure you need repeaters for the MOT, not sure how you could get away with not having any. If you get some go for UK spec ones, they look better than the jap ones (which I have). You will obviously need a hole drilled in each wing to fit them.
Do a trick job and stick some in your wing mirrors. :ph34r:
Which repeaters ?
toblerones or normal uk?
it will pass with either ..... mine passed with the jap ones on :D
hth
J
theyre required but its not really a thing that testers look for, just chance it and see if they notice
