Fuel Pump Wiring
IceHz
Does anyone know what is the color of the fuel pump wiring is? Need to cut it off to fix an engine immobilizer :eek: (no stock immobilizer in car)
These are the four wires that goes to the tank:
White/Black with 2 Silver lines
Black/Red with 1 Silver line
Brown with 1 Silver line
Purple with 2 Silver lines
have you checked which wires are live when the car is running, becarful try not to make any sparks
I hope that all wires are outside of the fuel tank....if not.... do not carry out this check with any power connected
Hiya Koliya,
The Black-Red wire is the live to the fuel-pump, the White-Black wire is ground. Both the Purple and Brown wire are for the fuel level "thingie". The Silver lines on the wires have no meaning.
Yves.
Thanks Yvvan.... black/red & white/black wires do look a little bit thicker than the other two... or my eyes are playing tricks on me :blink:
and thanks guys.. for the warning!!!!
Cheers :thumbsup:
Nah, nothing wrong with your eyesight. They are of a thicker gauge than the ones for the fuel level sender due to the amount of current flowing through them.
Let us know how you get on with your project. :thumbsup: (or send a mail if you don't want the details out in public for obvious reasons).
Cheers, Yves.
Cheers, Yves.
Thats what I thought...!!! will keep you posted on the developments :!Removed!:
K :D
  • 16 years later...
Hi i have a question i was tring to find fuel pump wire on my 2001 yaris and on the 3th position of key i cant mesure any power on any wire. I was tring to find it to instal kill switch
