Scion Brake Rotors...
vladrulli
was thinking on ordering a set of Scion front brake rotors for my TS...
anybody know if the US Scion uses the same front rotors as the Yaris T-Sport?
I know that Scion has rotors front and drums at the back but uses the 1.5L engine... so I'm not sure what size the front rotors are... anybody here who can help me?
:wacko:
The TS' front discs have a diameter of 255mm and a thickness of 20mm. the hat has a diameter of 141mm outside, a diameter of 129mm inside and is 37mm high (measured inside from bottom of disc to bottom of hat).
Don't know about the Scion ones but you could compare their dimensions with these ones.
Yves.
