High Torque Model
westwood
does anyone know what the difference is between the high torque model corolla gti and the non high torque one
The non tvis GTi (89-92) is in some places referred to as the high torque model.
As for differences:
Revised interior.
Bigger front disks (about 20mm bigger).
Non tvis engine produces a few more bhp and few more pounds of torque.
Also this engine block has slightly different (stronger) internals from the earlier spec.
Anything I missed?
Badge on middle of front gril is the Toyota emblem design on Non Tvis as opposed to the word Toyota on the earlier ones :)
Mine is a non TVIS (apparently) and it has a toyota on the grill, not the emblem.
do u know the exact figures for the bhp and the 0-60 times
They were both next to identical 8.2secs for the TVIS and 8.0secs for the NON-TVIS.
The TVIS model was 122-123bhp and the NON-TVIS was 129bhp.
You can fit twin carbs on the TVIS model. It's got a 200mm clutch whereas the NON-TVIS has got 212mm. TVIS brakes were 238 x 18mm, and the NON-TVIS was 258 x 22mm (more stopping power on NON-TVIS models).
Well it's either had a front end smash and had the grill replaced with a late spec one or someone just changed the grill. I changed it on my '87 Rolla GTI to the late spec. Thought it looked alot better with the T in the center rather than having a dated looking TOYOTA Badge instead.
did exactly the same thing, replaced the aged toyota Badge with the T, looks the part much better :thumbsup: do have a meshed out grill aswel that i made tho with just the gti 16 Badge in it, will be put on when i get my suspsension kit put on the car :yes:
  • 4 years later...
actually, i have a non-tvis from August 1990 with "Toyota" written on the front still!
the only way to be sure is to check the colour of the engine top-block.
The Tvis engines have the Tvis Badge on the intake manifold and the other non-tvis model has just lines.
Every GTi owners in this topic, POST YOUR GTI/AE92! It's stickied at the top of the rolla section. I want to see more! :lol:
Way to bring back a 4 year old thread...
