One For The It Techs
Jamesb4uk
Ok, i'm looking for a decent network firewall,
basically here's what i'm doing...
I've got a WiFi network comprising of 2 PC's & 3 laptops. All running XP.
the network is ad-hoc 128 bit encrypted, with the SSID hidden.
basically the ADSL link is AOL (Dont ask) connecting via USB adsl modem on 1 laptop with a shared PPPOE login to the rest of the PC's/Laptops.
I'm now looking for a Firewall to put on the laptop to secure it.
i've toyed with the idea of using Smoothwall but the DSL modem isn't suppprted natively.
Any idea's on a good firewall that will protect the rest of the PC's?
J
why not get a ADSL NAT router?
should support your existing network setup - if not, then it will be simple enough to make your network get IP's dished out by DHCP from the router.
and the fact it does NAT will make it act as a firewall as well. ;)
basically i've got a Linksys dsl router which does everything but i'm doing this as a learning process.
J
J
if you already have a NAT router - then this will act as an incoming firewall.
a software firewall on each of the machines would also be a good idea - but something like zone alarm would be sufficient
I use Clarkconnect with an ADSL Ethernet modem, rather than Smoothwall. This is only because Clarkconnect allows me to share printers connected to the firewall PC. So far (in ~12months) it has worked fine.
It is also a good idea to use someting like ZoneAlarm to prevent out-going connections from your PC's...
Richard
PS. Clarkconect also enables you to host a website, email server etc. etc. etc...
Personally.. for a software firewall, i prefer Sygate to zonealarm.
Shoot me if you want… but the XP sp2 firewall should be ok (shudder)
Have agree, XP SP2 Firewall is actually quite secure.
<hands CFC1 the gun....> :lol:
dunno what to try, i've used Sygate, Black Ice and Zone Alarm before as well as a few others.
XP firewall i refused to use at work, it caused so many problems with our network.
I might do a trial one on a few & see what their like..
Thanks guys..
J
