Car Won't Start After Being Driven When Its Hot
krispydude
I need some help on this. I have a 94 corolla with 119000 miles on it. After I drive my car for about 20 min in the really hot weather here in Phoenix, Az, it won't start again once i turn it off. I turn they key and nothing. Acessories come on no clicking or cranking. It takes about 4-5 hours before it will start again. I checked the EFI main relay in the fuse box but it looks like and it doesnt look like its overheating. Not sure how to tell if a relay is bad though. I really want to fix this myself and dont want to take it to a shop and get charged an insane amount of money for stuff I don't need. Any help would be appreciated.
Also its not overheating either. The engine gets to normal temperature and stays there.
Krispydude - it's a process of elimination, check the following:-
Alarm/immobiliser faulty.
Ignition Switch(electrical contacts on back of switch)
Inhibitor Switch(automatic transmission)
Dead Battery( not holding a charge or bad earth)
Starter Relay.
Starter Motor( most likely the fault).
Hope this help's you.
:thumbsup:
  • 5 months later...
krispydude
Were you ever able to resolve your problem?
I have the exact same problem with my 1990 Corolla, but haven't been able to resolve it.
