Update On Yaris Cat Failure
jay dh
all sort and repaired now
went to kiwk fit (i know) but they only charged £230 all in and it does come with a warrenty so...
we are selling the car soon anyway so not really fussed
we went back to toyota for a break down of the bill, the total was £770 for a new CAT all in. they said it costs the around £620 to get the part (from the moon i recon)
thanks for everyones help
Jay
When I was looking to justify the 'Envy mid section' mod to myself i called MrT is get a price for a standard exhaust. They said for the t-sport it would be £880 supplied and fitted for the full exhaust.
Now I already had the HKS backbox so it didnt take long to make my mind up!
makes sense
although ive just spoken to my parents and the car still has problems, oh well, back to Mr T for a diagnosis
is chugging still, its not a smooth ride
had the spark plugs and oil filter changed, then tried the lean burn sensor on cpu, then CAT, now will have to be something else. its gona go in for a service as well and sort out this mess
its a 99V freetronic 1.0
Im pretty sure theres a warning light code -
Should just be four bolts - take off - check gasket and retfit.
If not the manifold, you've changed the plugs but have you changed the leads?
occaisionally they do go, on my Seat which i had last they did and that caused a chugging.
probs not related but maybe worth a check
nick
nick
no plug leads..direct ignition. perhaps an ecu reset is in order. oxygen sensor in the cat needs to relearn itself?
