Pas Pump On Ep82+paseo
BenMorris71
I was wondering if anyone knew if they share the same pump? I'm putting the 4efte in my paseo, and am not sure which one I'll need to use on the Paseo
still in the early stages!
i recalled wrong then...but i would thing yes, purely on the fact that they share a lot of items....i just think the belt lengths will differ because the 4efte is a bit taller blockwise
the pump bodies are different between 5E-FHE Sera and 4E-FTE turbo, but the pulleys are in the same plane.
You can't fit a 5E-FHE pump onto a 4E-FTE because of a foul condition to do with the turbocharger
The positions of the fluid inlet and outlet ports could well be different
correct me if im wrong, but i thought that the 4efte had the same size block as the 4efe? and the 5e series were the ones with the slightly taller block?
Rich.
Rich is right. Block height on 4E-FE and 4E-FTE is the same, but different to 5E-FHE and 5E-FE
