Obd On A Avensis T3x (2004)
dogo
** Warning Newbee**
I have found the OBD-II connector near the steering it has a plastic cover over it and is marked OBD-II, now the question is can I use some software like this http://www.obddiagnostics.com/ProgWin.html
As I understand it many uk cars don’t support the OBD interface, so any advice is truly appreciated.
Cheers for any info
Hello dogo
The Avensis T25 plattform (03 &onwards) conforms to the EOBD regulation and is mostly compatible to the US OBD2 standard. You need the ISO 9141-2 protocol Interface an I use the gear from
http://www.scantool.net
for my Avensis and it works a treat. Had to simulate a sensor fault in order to validate the DTC and resetting of MIL.
:yes:
Thanks for the info, Just need to find a uk supplier for the hardware that comforms to this ISO 9141-2 protocol Interface standard
Once again thanks
Dogo
I just came across this supplier via Google:
http://www.gendan.co.uk/viewproduct.php?pr...uct_information
Anyone got any experience with this?
Edit: this one looks similar (sans software), and is a lot more affordable:
http://www.ecufix.com/shop/index.php?main_...products_id=182
Eddy
