Faulty Rear Fog Switch/indicator Stalk
purvesh81
I've had the dealership test the bulbs, bulb holders and fuses - all are OK. :blink:
That leaves 2 options:
1). The wiring (which I doubt is at fault)
2) The Indicator stalk which has the rear fog switch on it.
I luckily found an Indicator Stalk from eBay but my question is, how do I remember the trim around the steering column to fit the new switch.
I know I've left it late, but I need to do it asap, as I have an MOT booked tomm at 3pm!
I can only see one screw under the steering wheel trim, and no ideas how to take it off after that. <_<
The car is an Avensis 99/V (Mark 1)
Any help or advice would be greatly appreciated!
