Turbo Q
TOYMOTA
Will a CT26 turbo from a REV 1 go staright onto a REV 2 without any probs??
I think the answer is yes, but just wanna double check. :thumbsup:
yeah, and so with a CT20 of a gen3 block (and it'll give you more power) and so will a CT26 off a mk3 soop.
A friend of a friend is selling one. Thought maybe if I can get it for under £50, then it may be worth getting just in case my one should blow at some point.
Get it for less than £50 then see if you can use it and your own to part up a CT20b could be a cheap way to more horses  :)
Do you mean try and sell both, and then get a CT20b?? Hmmmm, good thinking Batman!!!
