Anyone With A How To On Bleeding A -- Clutch
sera_beetle
Hi guys
I have been speaking to andrew (toyotsera) and he thinks it might be air in the clutch fluid..
does anyone have a How to on bleeding the clutch please?
I know how to bleed it! it's more which bits do i undo? sorry this is for a 4efte starlet engine.
Many thanks
Tim :thumbsup:
There is a bleed nipple on the front of the clutch slave cylinder on the front of the gearbox. Bleed in the same way as you would brakes.
i usually take the slave cylinder off from the bell crank then take the piston out and clean it before bleeding it. makes it a lot smoother
