Engine Mounts
daviduofa
Hey guys, i need help.....i need to change out my engine mounts, i'm assuming those are bad b/c when i accelerate it makes a clunking noise. Anyways...they need to be changed anyways...i need to know where they are all located at? i've only found two. thank you for your time
David
And you drive what exactly?
They are on the engine in anycase. Black rubber bushes attaching the engine to the car. You really shouldn't miss them. ;)
i think there should be 3.
2 on the engine and the other on the gearbox.
alright i'll look for 3 or so...is there a online picture or diagram can look at so i can spot them easlier? thanks
