Granvia Rear Seat
Argy
:D Hi. I am a new member. Have recently bought a 96 Granvia 7 seater to use both for family as well as business. Am extremely happy with the Granvia in the way it goes and is put together. Mine is a 2nd hand import as are all Granvias here in new Zealand. There are loads of them around so parts won't be a problem. Am yet to aquire an English handbook but what I wanted to know is how easy it is to remove the rear bench seat as I occasionally need the extra room for business. Any one got an idea? Cheers
the only way is updo all four bolts and left the seat brucket on,
Thanks for that. Did go to the local Toyota Dealer to see if they could help but they were not sure either and suggested it might be easier to remove the 2 middle seats completely and slide the rear seat forward to replace them. Does that sound workable? My only concern with removing the rear seat only is that the sliding brackets would remain and how difficult would it be to remove the rear benchseat adjustment cables from the brackets? Cheers
if u remove the mid seat with all runner rail, otherwise rear seat can't push forward,
becasue of all seat rail still on the floor
push the cable off from clip, then loss cable from hole
