St205 None Starter
j8nny27
:( HELP me someone pleeeeaaaase problems startin my st205, it cut out on me 2 weeks ago after droppin onto 3 cylinders, figured out the fuel pump had :censor: up, since replaced it but wont start still thought the rotor arm was faulty so replaced that to still no joy :angry: , turns over fine should start any ideas anyone? tried the diagnostic check but the engine light just flashes continiously no pauses so no code any ideas on that one to please?
if you have a spark, crack the 17mm banjo nut ontop of the fuel filter try turning over for a sec or 2 and check if fuel comes out if not check the fuel pump resistor and relay
You need to approach it logically which could take a bit of time. Are you
1/ Getting a spark at the plugs? Yes.... Check fuel supply. No..... Check for spark at distributor end of coil/ignitor HT lead. Is there a spark here? Yes..... Then it`s likely to be the dizzy cap or rotor arm. No....... Check the voltage supply to the ignitor. Is there a 12V - 14V supply to the ignitor.
