Checking For Air In The Water System....
saxokiller
:help: Can anyone tell me the best way to find out if there is any air in my coolant system?The reason i ask is coz i was out the other night with a friend and we noticed the temp needle had hardly moved even after a 30 min drive?Its a late spec 92 non tvis engine? :blink:
As all of my old corolla`s used to run around the half way point :blink:
But they were all tvis engines!Should i be worried :blink:
Max Res Trevor AkA Saxokiller :ph34r:
Are you using any water? Have you checked the water level in the expansion tank lately?
If it's not using any water then it's probably the thermostat stuck open.
Dude,Its not used any water since i bought the car (last sunday)so it might well be the thermostat!
Anyway of checking it do u know?
cheers Trevor
cheers Trevor
I have a similar problem with mine. When i'm driving it, the temp stay's cold but if I stop and leave it idling for a few minutes, the temperature rises to half way and stops.
I think its the termostat but it doesn't seem to affect anything so I've never had it l looked at :wacko:
you really should put a new stat in as asap , your engine will be running cold and using more fuel , it wont be helping things at all - toyota stats are a common issue where the clip that holds the springs shaft in place comes off , jamming the stat open . £ 17 ish dealer part , dont buy copied items when it comes to toyota waterworks
Hi guys thx for all your replys,Ive just bought a new stat and i will be fitting asap!
Does anyone have a idiots guide or step by step guide on the best way to change it?
Max Res Saxokiller
