Buy An Fj60
serpico
I was driven across Tibet recently in an 80's Toyota Land Cruiser FJ60 the car took one hell of a pounding and barely even noticed. I would like to buy one of these fantastic vehicles, does anyone know where you can get a right hand drive FJ60 in the UK? Many Thanks.
The best place anywhere to purchase a good low klm landcruiser is from Japan.There are importers in most countries inc the UK.
The Japanese models are usually fully optioned and typically have less than 150000klms which is not much for these.
Also they are RHD
Get the turbo diesel which will have the same power (or more) and use 30% less fuel. The FJ60 is a petrol model and HJ60 OR 61(TURBO) are the diesel models.
The 60 series was built from 1980-90 and comes with 2F,3F 3Fe(injected)petrol engines
The diesels are the cyl 2H 12HT (turbo) and 4cyls 3B and 13BTturbo)
The pre 84 models are 4sp and later an auto and 5 sp was offered from 85 onwards.
Not all engines or gearboxes are available in all countries.
If someone offers you a 70/73/74/75 series you will get the same cmponents in a different and slightly smaller body but equal in every other respect.
Anyway you have made a good choice and Im sure ou will be happy with it.
Australia has imported about 500000 since 1970 in a pop of 20m because they are the only thing that holds together on our roads.
