Looking For Brake Light Wiring Info
sgh
Anyone know which colour wires are the reverse light & earth in the brake light cluster ?
Steve
If I remember correctly, the wire for reverse light is furthest away from the rear quarter panel.
As for the earth, use the nut that holds the light cluster in place.
Are you trying to connect up reversing sensors by any chance? If so, connect everything up apart from the reverse wire, turn the ignition on and put the car in reverse. Then just put the reverse wire for the sensors in the top of the connector, it will light up once you have find the right one.
