Pioneer Key
System~G
If there is anyone going to JAE that has a "key" to remove a Pioneer DEH3000R head unit from it's mounting (or anything that will do the job without damaging the unit) please contact me. I am trying to do a wire trace as all the Speakers in the rear on the driver's side of my '2 are not working... I don't think they are blown and have put it down to faulty wiring or amplifier. It has the 8 speaker setup (with a "sub" behind each seat). It's the type with two flat (rectangular) slots on either side of the head unit and are in the middle (i.e. on the vertical). The head unit itself should be able to be removed from the mounting bracket (frame), which is bolted in place. I would imagine one would see the bolts once the head unit is removed from the frame. The stereo system was already installed in the car when I bought it and was unfortunately supplied without the key to remove the head unit.
i think i have the ones your after.....and im going to JAE
I have the keys too, i will try and remember them as a back up :hokus-pokus:
Dan :thumbsup:
