Engaging 4wd On A Surf
GT4 BOOSTER
my 4wd isnt engaging so can someone tell me the procedure to engage 4wd on my surf . like at what speeds can i do it , will it engage standing still or do i have to be moving , do i need to lift off the fuel pedal , my light on the dash isnt lighting since i had an alarm fitted 3 days ago , i;m wondering if the bulbs blown or if a wires been cut somewhere .
its a 5 speed manual , i know not to use it on dry tarmac - can i simply jack up both wheels and try turning them to test if its the dash bulb or not . anything else i could try , i hear a relay click when i press the 4wd button . :help:
its working now , the knob that fitted the alarm had jammed a vacuum pipe ,closing it - i freed it off just now and the 4wd system is working again.
i will be calling the alarm people next week . useless ham shankers.
Glad to hear that you 'fixed' it ;)
Any chance you can send me some interior shots of your 5sp Surf as I am hoping to fit one into my mk3 HiLux, no rush but it would be really helpful buddy :thumbsup:
I'm hoping to use the carpets, the door cards and the nicer manual gear lever surround B)
ben1974rsv@btinternet.com
