Lowering Springs! Help!
xplayboy_babeyx
i currently have my tsport lowered -40mm but i cant get over speed bumps without scrapping my bumper! i tried ordering -25mm gmax springs but they no longer sell them. i was then told that tsport springs are already about -20mm?! so if i could get my hands on them it should be fine?
Hey! Thats the 3rd owner of that car that has been in this club :D Congrats on an awesome car!
To answer your question, the Tsport Spring DO NOT lower the car in anyway. The Tsport IS lower than a standard yaris but this is because of the chassis being different. If you still want the car lower than a standard Tsport, a set of TTE springs (-30mm) or a set of SR springs (-20mm) can usually be got hold of through eBay. If you want the normal Tsport springs it will be normal Tsport height (i.e. 20mm lower than other yaris' but not due to springs) I think the Tsport springs are the exact same as used on the other yaris range it's just the shocks that are different on a Tsport that give it a sportier ride than the rest of the range (i think)
Hope that was of some use and welcome to the club :D
To answer your question, the Tsport Spring DO NOT lower the car in anyway. The Tsport IS lower than a standard yaris but this is because of the chassis being different. If you still want the car lower than a standard Tsport, a set of TTE springs (-30mm) or a set of SR springs (-20mm) can usually be got hold of through ebay. If you want the normal Tsport springs it will be normal Tsport height (i.e. 20mm lower than other yaris' but not due to springs) I think the Tsport springs are the exact same as used on the other yaris range it's just the shocks that are different on a Tsport that give it a sportier ride than the rest of the range (i think)
thanks very much! x
