Steering Box
Coyote!
Yeah, hi every-1!
well I made myself some time to come back to TOC. Unfortunatelly here dont let me time even for breathing...
I have one question, and I wanted to check it with you guys that have more experience working in Carinas.(I have never have to repair her, yet!)
1° The steering box has became a little bit noisy, with the engine off I turn the steering wheel and I can sense this clonking noise inside the steering
box assy. Could it be a problem of lubrication?, or anything broken? ( the wheels movement is pretty accurate, there is nothing loose when I drive it, just noise)
I would like to remove the rubber things that seal it, in order to access to the teeth. But again, Is it possible to lubricate this? Haynes
says that when you change the joins, you have to lubricate with steering fluid (ATF), I didn't understand where...
Please, I know there are some experts out there, please give me a piece of advice!!!
Cheers and thanks in advance!!! :thumbsup::thumbsup::thumbsup:
Coyote from BA
ARGENTINA
