Dashboard Lights Not Working
wkm
Hi everyone, I have just registered hoping someone can help me with my problem. I have a toyota startlet LXi 1993 and all the lights on the dashboard are gone, all the other lighting is ok. Is there anyone out there who knows how to fix this problem.
Cheers.
the interior lights usually run of a single fuse. but that includes the courtesy light inside too... if by all the other lights are workin u mean mean all exterior lights, then its probably just a blown fuse....
Thanks for the tip Mellow Yellow, I certainly will give it a go and see if that is the case, if not, no doubt, you'll be hearing from me again.
Cheers, once again.
