New Headunit Soon...
matt5cott
Ok I have a standard double din toyota HU in at the moment...
I got a cubby box sent over that sits below a single din HU, so that should work out fine.
However, anyone know if I need a wiring conversion kit? if so what one?
Its a 1998 model, not sure if it differs from earlier models or not :unsure:
To replace the existing headunit in an MR2 (assuming it's not got the 'active speaker system') then you need a wiring loom, the PC2-17-4, available from Halfords for around £11.50.
I also replaced my Toyota blanking plate with a DIN Pocket from Halfords for £29.95, although can be found on the web for a bit cheaper, it's the FP-11-01.
http://www.incardiscount.co.uk/acatalog/FA_TOYOTA.html
I do have the active speaker system...
I bout the £11.50 part to find it was the wrong one... so I had to order the one for the active speaker setup. It cost me £45 !!
what does the FP-11-00 Facia Adaptor do ? Does it basically cover one slot up so you don't have a great hole under your single din unit?
I take that the mentioned bit of kit works ok to convert jap models? :)
