Rear Washer
camels toe
HI CAN SOME ONE HELP ME MY REAR WASHER DOESENT WORK, HAS IT GOT ITS OWN WASHER PUMP OR DOES IT JUST RUN OFF THE ONE,I HAVE THE CELICA ST202 THANKS
  • 4 months later...
The rear will have its own motor/pump.
If you can get someone to work the rear wash/wipe while you listen at the front for the sound of the motor/pump 'whiring'.
If you cant hear anything its most probably in need of a new pump, you can check the wiring too by simply swapping the plugs between front and rear motors/pumps. If the rear wiring works the front pump then its definately the rear motor needs replacing.
Hopefully that isnt too complicated......it always makes sense in my head but not always when i type it! lol
Good luck
Mart
