Need Help With Vvti Idling Problem
gbbrycem
I have a Celica 2003 VVTi car that has an idling problem when it is cold. If the engine temp is at cold it tends to stall at junction and flood meaning I have to turn the ignition off for 30 seconds and then restart. As soon as the engine temperature has risen to anything above 0 temp it is ok(i.e. doesn't stall).
I have been running on LPG(I had it converted 1 year after i bought it) and Petrol with no problems for 2 years. Since the idling problem I have disconnected the LPG for over 4 months and now only run on Petrol. My Toyota garage has changed the Oxygen sensor no. 2, cylinder valves, idling valve and cold start components and the problem is still evident.
Has anyone got any ideas/suggestions on what the problem could be?
