Carina E Engine Problem
g_4toyota
hi guys
i am new here and also my english is not so good...
I have a '96 Carina E sportwagon, 1.6 Gli, 200.000 km...absolutely very good car...from a while I have some problem with the engine...starting up very well, driving couple of km very fine and after is hot enough and accelerating in 3rd, 4th and 5th the engine is interupting... so, when you push the gas you have the feeling that the engine has no air and after you push down at maximum is feeling like some turbo comes up...
I changed spark plugs, wires, distributor and cup, air filter, gas filter, everything genuine, done also some injector cleaning job, took out the kat and still the same... no error code, I really need some help on this...
thank you in advance
