Am I Mad
cmarshall
Just found out i can get insured on a supra TT manual, soon turning 20. Before i go ahead and take the plunge i need to know the running cost i.e. MPG, service intervals, cost of service, are they reliable thanks people.
Chris
Realisticly you will average 15-20mpg. Services should be done every 3000 miles if you want the car to run in tip top condition. As long as you take care of the car then they are pretty reliable :thumbsup:
AS said above really...
Look after it yourself is the best bet... preventative mainteneance is the bes tfor of keeping them sweet, learn the car, and be vigelant to spot potential problems before they escalate.
Make sure you use proper coolant too... the amount of coolant systems I have seen fail due to using antifreeze water is silly!
