Avensis Heater And Aircon Problem
ian1905
I have a 98 Avensis 1.6 GS. On switching the ignition off the Heater Fan and/or Air Con remain on. A few minutes a click will be heard and they will switch off. Other electrical items power off as normal.
I suspect a Dodgy relay. Does any one have any idea which one and where it may be located.
Ian
Do you mean cooling fans or interior blower?
If you are talking about cooling fans in engine bay, then this is perfectly normal. Fans usually "Run on" if you have been using your A/C.
  • 20 years later...
Jag har en Toyota Avensis från 2007. Passagerarsidan ger sval luft vid höga temperaturer, men förarsidan ger hög värme. Jag undrar vad det beror på?
