Throttle Housing Cleaning - Haynes Alarmist?
bernado
I'm going to give the throttle housing and the ICV a good clean (idle's a little high and throttle sticks a little). According to Haynes you need to disconnect the Battery, presumably as a precaution against sparking. Is this really necessary? I can't help thinking taking the Battery out is going to introduce new problems with security systems, radio coding etc. Paranoid? - probably; Newbie? - definitely
