Carina Abs Light
northcoaster
Hi all,
97 Carina E 1.8 Today the ABS lit up, turned car off, started up again, fine no ABS light. The engine management light is NOT lit. Sounds to me like a faulty connection, the question is where is the best place to start ?
Cheers
Dust on sensor at wheel end?
Cheers Gazza, I am still coming to terms with all this electronic sensors, ecu's etc. Will let you know how I get on.
Thanks again
Petrol tonight 102.9 ppl unleaded !
And so it continues.......
Getting code 35 from the ABS ECU, which means front left/ rear right sensor(s) connector , wiring. Can anyone tell me the resistance from a healthy sensor ? I have checked the front left, the reading is about 1.623K ohms
I noticed the manufacturer of the front sensor are Bosch, will these be available from factors rather than buying from Mr T ?
The front wing underguard was a real b****r to come out.....what is the easy way to remove the screw fixings going into the wing ?
Plan to tackle the rear right tomorrow........
Cheers
Northcoaster
  • 1 year later...
Hello, I am a new user of this site and a new Carina owner :)
So as not to start another thread, I thought I could post here. I'm having the same ABS always-on light issue. After letting the car warm up and turning the engine off and on, it usually disappears, but when it's raining it can come up again during driving. I went to a repairshop and we thought it's one of the sensors but apparently there is nothing wrong with them. Can there be another cause?
