Which Spark Plugs For 3sge?
tariqf
Hi everyone, trying to work out which spark plugs I should put in my 3SGE (ST191). My local toyota dealer reckons that it doesn't use platimum plugs as they are only for lean-burn engines. This doesn't seem right to me, £10 for 4 spark plugs sounds a bit cheap to me, I'm worried these aren't going to do me justice. Fensport can provide heat range 6 & 7 platimum plugs, should I use these instead, and which heat range? My engine is un-modified.
Can anyone advise?
I´m using Beru Ultra X on my 4AGE and i´m very happy with it, altough dont know if they are available for your motor....
Later
Iridium spark plugs are the best. Provides the best spark and lasts forever.
NGK, Blitz, HKS and TRD make Iridium Sparks in heat Grades 6 7 and 8
heat grades depend on how much bhp your running. If you call fensport to buy them they can advise on which grade.
www.fensport.co.uk
  • 3 months later...
Just got the blitz Iridium sparkplugs & magnecor leads from fensport for my N/A MR2. The guy advised that 7 was the best (which i got).
-Z
