R Reg Avensis Wont Start When Cold
madbrit
I have an avensis R reg, 1.8 gls
It wont start from cold, been to toyota(for what they are worth) they say they cant find a problem,
It tries to start, but seems like a lack of fuel or spark.
It has just had a B service in the hope of curing the problem, but NO....
It has an LPG conversion about a year ago, disabled that and still non starter,
when it does start, it has to warm up before i can touch the throttle or it will stall.
Any ideas ???
MaD
Sounds like an intermitent fault? I would suggest that the fault is probably linked to the air-flow meter. Check all the connections.
UPDATE.... changed plugs and leads, and it starts now, but still wont rev up til its warm.
Where do I find the airflow meter ??
MaD
Has the car done a few miles ? sounds more like the coil packs to me. dose it start for 5 seconds then cut out ? if it dose try another key as these can be faulty as well.
  • 4 years later...
s the crankshaft position sensor, all cured now
Thanks to all
was the crankshaft position sensor, all cured now
Thanks to all
MaD
it is located on the throttle as built in having wire
cheers
