Another Induction Kit Topic With A Twist
sphinktar1988
Right i have the blitz filter now and have for 2 months
thinkin of gettin rid of it
as its making my flat spot worse
would be fine on a normal yaris jst with my havin the stupid flat spot :@
i like the noise it makes its spot on im aware of the other filters on the market
and most says the apexi is the best but also its supposed to be quiet
also wat kinda diffrence am i guna notice between a panel and induction kit
wat else is good for the sr
also is anyone trying to flog an induction kit or panel filter at the min?
cheers
thats good :) cause i dnt want quiet n thats wat im veering toward
but its not as loud as the blitz?
cause the blitz sounds n looks unreal
With a panel filter you'll notice a bit more lower down pull when driving, and with a induction kit you'll gain top end.
But panel filters aren't noisy.
Apexi is NOT quiet.
It's quieter than the blitz.
You couls always try the K&N.
Maybe you should try and find out what's causing your flat spot before buying another filter, as I don't think a new filter will cure anything.
flat spot which after a year i ave now renamed the tw*t spot :@ is gettin looked at in a months time so about the same time im looking to change my filter
hmmm strange my decat and induction made my low end power much better but my high end power is naff now
You want a loud kit get the typhoon! Best relocation around, filter is good maybe not as good as apexi but still dam good.
Looks the dogs aswell!
The Apexi isn't particularly quiet but put your foot down and the noise then kicks in!! Never heard the Blitz before but certainly can't complain about the Apexi one little bit!!
