Rally Axle
Jon1
Hi All
I am looking for some help with a Toyota axle i am using in a rally car. My current set up uses a Celica 56" wide axle casing with a AE86 LSD and 4.1 crown wheel and pinion. This is proving a little weak and i have just stripped the teeth off the pinion. i also have a larger (approx 9" diameter) 5.1 LSD unit also Toyota which is far more suitable but the question is what axle casing i can put this unit into that is about 56" wide or can i source a stronger 5.1 crown wheel and pinion for the current set up that will cope with 235BHP and if so will the shafts then break?
Your help would be greatly appreciated
Jon
