My Car On A Dyno
Bibbs
the screen wash is a 50/50 mix - or near enough.
You could also map it too boost via your chip .. and then set boost back to 15 psi when the water runs out ..
good idea... although the bottle I will be getting is pretty big.. so if I keep an eye on it, it shouldn't run out.
Will speak to my Japp garage about the chip and increasing the boost.. as I dunno how they set it to 15PSI in the first place.
