About Mtec "xenon-look"
Speed_Chaser
Here are the MTEC "Cosmos Blue" xenon-look bulbs. Is it even possible, that the light is so blue?
This bulbs are 100 W. They could damage wire instalation.
i use standard wattage..consume 55w but produce lighting equilivant to 100w...i've been using it for 6months, now, no porblems at all, not wiring damage. it looks blue but visibility is lower
theres a extended wattage which 140w output..dont get that caz they will melt the wirings i heard.
There is also 55w version available... Can see it on the site.
Or does it look different?
What is the name of bulbs that you're using Sugizo? And is the visibility lower compared only to 100w version, or also to the stock halogen? I think that those bulbs should be better than normal halogen, if both have the same wattage of course...
