Yaris Sub
supafly
easy
you need to get the wires for the rear channels off the OE stereo. these then connect into the converter box which you then connect to the amp with the use of an RCA cable.
the converter may also have to be 'powered' eg. itll have a 12v input feed (from the Battery or back of the dash etc) and a ground point (simple) also it may have an ignition sense to tell it to switch on (any wire that is 12v live when engine is running - same thing that only alows the headunit to come on when the key is in and clicked round once)
:thumbsup:
