Wheel Bolts
weevicky
Will these fit aygo wheels
http://cgi.ebay.co.uk/16-Chrome-Alloy-Whee...id=p3286.c0.m14
I'm curently using steelie bolts for alloys for toyota wont supply me the parts because there are :censor:
can't see why not, they say they will but beware cheapo chromed ones as when you tighten them, the chrome plating scratches and lets water in causing rust.
No. They look like Peugeot bolts with 1.25mm pitch whereas you need 1.5mm. Another thing to watch out for is that if you fit bolts which are too long they will foul the inside of the rear drum and that will cause big trouble.
I recommend trying before you buy :thumbsup:
Paul.
Paul,
How long should the bolts be?
I am looking for a set of bolts for my 15" alloys that need ones like the std bolts.
Paul,
I am looking for a set of bolts for my 15" Alloys that need ones like the std bolts.
I'm afraid without seeing the wheels it's difficult to say. The stock steel wheels take bolts which have about 12 threads but if you buy TTE alloy wheels they give you a set of longer bolts which have about 15 threads.
Why don't you try putting your stock bolts into the alloys and see if you have about six threads poking out where the hub would be.
Paul.
Hi Paul,
I already has std 14" toyota alloys with those expensive bolts fitted as std.
Not going for TTE wheels, . You saw the car at JAE (next to the Marque)
Hi Paul,
Yes I know :D
You already have a set of standard bolts in your locking wheel nut kit box. You can try those on your 15in alloys can't you? If they aren't long enough you might try the TTE bolts.
Paul.
