Sunday Car
GreyRacer
Hi guys, I've just popped over from the Auris side. Also been a member of the Corolla forum when I owned a couple of TS.
Currently in a Auris T180. I'm planning to buy a new ''Sunday'' car for myself. A 2006 Celica T Sport with 31K on the clock. Being sold though my local Toyata dealer, Approved. I'm well used to the engine so know what to look and listen for there.
Is there anything specific to this model though that I should pay particular attention to when I go to inspect and drive it?
Many thanks.
Corrosion on the inside faces of the Brake Discs and buckled alloys (assuming they're the eight spoke OE Rims) leading to vibration at speed :)
Being an approved used car i wouldnt worry too much B) Not as if you are buying off a dodgy backstreet garage.
I'm sure as you already know, just check that the oil and water levels are ok and there are no funny noises from the gearbag when cold :P
