Outside Temp Gauge
Goggy
Hi Guys
Please can you tell me if it is possable to change the temp reading on my 4.2 XTR from degrees c to degrees f as i am a old git and perfer 70 degrees f it sounds HOTTTTER. :D
Hi Guys
Why change? Celcius is more logical. Freezing below 0, boiling at 100 and pleasant at 25... It's also the preferred scientific unit by the way...
back to topic... I'm pretty sure that it is changeable, but google didn't turn up any good answers, so unfortunately I cant help you with this. Have you talked to your local dealer?
Hi Guys
yes u can i did it on mine cant remember now tho ! think u get a menu up on the radio and also changes mpg to kph sorry cant be any more help
press the knob on the right hand side of the radio in and hold it then change by rotating to change /mpg km but not the temp
Hi Guys
More Logical yes but i am english logic does not come in to it :P
Thanks anyway Guys
As mentioned a couple of posts up...Push in the right Radio control knob and all settings like this can be altered....
Thanks Guys I will try it in the morning
