Removing Posts
Raistlin
Can we have the ability to remove our own posts.
Things can be said which on reflection could be misconstrued or just plain rude and after careful consideration need to be expunged. :rolleyes:
you can always edit out the offending post.
of course if it's been quoted it will appear in that post but I suspect that's even true if the original post is removed completely.
awa an get a life!!
Jist keep takin the tablets an we'll aw unnerstan !! :lol: :lol:
One might suggest that you should think before you post and if in doubt, don't post until you're satisfied with your comment..... :thumbsup:
Like has been said, you can edit your own post and remove anything you like, if it has been quoted you can PM the member who has quoted you and ask if they don't mind removing it from their post.. however, should they refuse then you have to respect their decision.
If you started a topic you can PM a moderator and ask that it be closed or removed, this will be seriously looked into and any appropriate action will be made.
